C asamblėjos pertvarkos
I
ibrar
hi all
Ar jūsų kūno paversti šiuos kodus ir surinkimo.Šie kodai yra už jhd12864 GLCD.
Ačiū
# include <reg51.h>
# include <intrins.h>
typedef unsigned char uchar;
typedef unsigned int uint;
sbit L_DI = P2 ^ 0;
sbit L_RW = P2 ^ 1;
sbit L_E = P2 ^ 4;
sbit L_CS1 = P2 ^ 6;
sbit L_CS2 = P2 ^ 7;
sbit L_SET = P2 ^ 3;
sbit bandymas = P3 ^ 5;
float ABC;
uchar kodas X1 [] = (
0x30, 0x50, 0xd0, 0x90, 0xf0, 0x30, 0x80, 0x60, 0x3c, 0xe8, 0x20, 0xa0, 0xE0, 0x70, 0x00, 0x00,
0x04, 0x06, 0x03, 0x11, 0x13, 0x12, 0x18, 0x0c, 0x07, 0x01, 0x03, 0x06, 0x0c, 0x1c, 0x18, 0x18
uchar kodas X2 [] = (
0x40, 0x58, 0x58, 0xd0, 0x10, 0xf8, 0x98, 0x08, 0x88, 0xf8, 0xf0, 0x10, 0xf8, 0x70, 0x00, 0x00,
0x0c, 0x04, 0x04, 0x07, 0x04, 0x05, 0x0d, 0x0d, 0x08, 0x1f, 0x1B, 0x19, 0x38, 0x38, 0x18, 0x18
uchar kodas X3 [] = (
0x30, 0x30, 0xf8, 0xf8, 0x08, 0x10, 0xd0, 0x50, 0x50, 0xfc, 0xfc, 0x50, 0xd0, 0xf0, 0x10, 0x00,
0x00, 0x00, 0x1f, 0x1f, 0x10, 0x10, 0x13, 0x1B, 0x0f, 0x07, 0x05, 0x0d, 0x09, 0x19, 0x38, 0x18
uchar kodas X4 [] = (
0x00, 0x00, 0x00, 0x00, 0xfc, 0xf8, 0x48, 0x48, 0x48, 0xf8, 0xf8, 0x48, 0x48, 0x48, 0xfc, 0xf8,
0x10, 0x10, 0x18, 0x1E, 0x0f, 0x01, 0x01, 0x01, 0x01, 0x3f, 0x1f, 0x01, 0x01, 0x01, 0x3f, 0x3f
uchar kodas X5 [] = (
0x18, 0xfc, 0x08, 0x48, 0x48, 0xb8, 0xd8, 0x58, 0xe8, 0xb8, 0xb8, 0x08, 0x08, 0xf8, 0xf8, 0x00,
0x00, 0x1f, 0x11, 0x11, 0x11, 0x14, 0x15, 0x16, 0x16, 0x10, 0x11, 0x11, 0x11, 0x3f, 0x1f, 0x00
uchar kodas X6 [] = (
0xc0, 0xc8, 0xc8, 0xf8, 0xf8, 0xc8, 0xf8, 0xf8, 0xc8, 0xc8, 0x00, 0x10, 0x90, 0xd8, 0x48, 0x48,
0x18, 0x18, 0x0c, 0x0f, 0x03, 0x00, 0x1f, 0x1f, 0x10, 0x10, 0x11, 0x19, 0x18, 0x0c, 0x04, 0x06
uchar kodas X7 [] = (
0x00, 0x00, 0x00, 0xE0, 0xE0, 0x40, 0x40, 0x7c, 0x7c, 0x58, 0x58, 0x58, 0xd0, 0xd0, 0x00, 0x00,
0x10, 0x18, 0x08, 0x0d, 0x03, 0x19, 0x0d, 0x01, 0x01, 0x0d, 0x19, 0x01, 0x07, 0x0c, 0x18, 0x38
uchar kodas X8 [] = (
0x08, 0xf8, 0xf8, 0x48, 0xe8, 0x98, 0x90, 0xd8, 0xf0, 0xbc, 0xfc, 0xd0, 0x90, 0x90, 0x90, 0x10,
0x00, 0x3f, 0x1f, 0x02, 0x03, 0x05, 0x06, 0x07, 0x07, 0x06, 0x3f, 0x3f, 0x06, 0x06, 0x04, 0x04
uchar kodas X9 [] = (
0x10, 0x08, 0x1c, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x08, 0x04, 0x04, 0x98, 0xf0, 0x00,
0x80, 0x80, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa0, 0xE0, 0x90, 0x8a, 0x83, 0xc1, 0x00
); / * 12 * /
uchar kodas X10 [] = (
0x00, 0x78, 0xc8, 0x84, 0x04, 0x84, 0xf8, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x80, 0x80,
0x00, 0x78, 0x84, 0x83, 0x83, 0x8e, 0xfc, 0x40, 0x00, 0x80, 0x63, 0x17, 0x1c, 0xf2, 0xc1, 0x80
); / * 8x * /
uchar kodas x11 [] = (
0x00, 0x80, 0xE0, 0x10, 0x08, 0x04, 0x04, 0x00, 0x00, 0x00, 0x80, 0x60, 0x10, 0xf8, 0x00, 0x00,
0x00, 0x7f, 0xc2, 0x81, 0x81, 0x81, 0x7f, 0x18, 0x00, 0x0e, 0x09, 0x08, 0x08, 0xFF, 0x08, 0x08
); / * 64 * /
uchar kodas X12 [] = (
0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa,
uchar kodas x13 [] = (
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
uchar kodas X14 [] = (
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
uchar kodas X15 [] = (
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
uchar kodas x16 [] = (
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80
uchar kodas x17 [] = (
0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
uchar kodas x18 [] = (
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF,
uchar kodas X19 [] = (
0xFF, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
uchar kodas x20 [] = (
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0xFF,
uchar kodas x21 [] = (
0xFF, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80
uchar kodas x22 [] = (
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0xFF
uchar kodas x23 [] = (
# pragma REGISTERBANK (0)
tuščia initcomm (tuščia)
PCON = 0x80; TMOD = 0X21; SCON = 0x50;
TH1 = 0XFa; TL1 = 0XFa; TR1 = 1; ES = 1;
TH0 = 0; TL0 = 0; TR0 = 1; ET0 = 1;
EA = 0;
tuščia vėlavimą (tuščia)
uchar I, J;
abc = 0,1 * 5;
for (i = 0; Aš! = 0xFF i )
for (j = 0; J! = 0xFF; j );
tuščia LCD_C_D (BIT vėliava, uchar ldata) / * vėliava = 1 con vėliava = 0 duomenys * /
uchar duomenis i;
L_DI =! Vėliava; L_E = 0; L_RW = 0; P0 = ldata;
_nop_ ();
L_E = 1;
_nop_ (); _nop_ ();
L_E = 0; L_RW = 1; L_DI = 1;
for (i = 0; i <10; i );
tuščia dis_one_zi (uchar x_add, uchar y_add, uchar kodas * PO)
uchar I, J, W;
j = x_add * 2 0 XB8;
W = (y_add <4? y_add: y_add-4) * 16 0 x40;
L_CS1 = (y_add <4);
L_CS2 =! (Y_add <4);
LCD_C_D (1, j);
LCD_C_D (1, w);
for (i = 0; i <32; i )
if (i == 16)
LCD_C_D (1, j 1);
LCD_C_D (1, w);
LCD_C_D (0, * PO );
L_CS1 = L_CS2 = 0;
tuščia CLRLCD (uchar numeris)
uchar duomenis i, j;
L_CS1 = L_CS2 = 1;
for (i = 0xb8; i <0xc0 i )
LCD_C_D (1, i);
LCD_C_D (1,0 x40);
for (j = 0; j <0x40; j )
LCD_C_D (0, numeris);
L_CS1 = L_CS2 = 0;
void main (void) naudoja 0
uchar duomenys I, J, skaičių;
uchar kodas * p;
initcomm ();
L_SET = 0;
L_SET = 1;
LCD_C_D (1,0 X3E );/**/
LCD_C_D (1,0 XC0 );/**/
LCD_C_D (1,0 X3F );/**/
CLRLCD (0);
while (1)
CLRLCD (0);
LCD_C_D (1,0 X3E);
p = X15 ;/*????*/
for (number = 1; skaičius <7; numeris )
(Dis_one_zi (0, skaičius, p);)
p = X16;
(Dis_one_zi (3 numeris, p);)
p = x17;
for (number = 1; skaičius <3; numeris )
(Dis_one_zi (numeris, 0, p);)
p = x18;
(Dis_one_zi (numeris, 7, p);)
p = X19; dis_one_zi (0,0, p);
p = x20; dis_one_zi (0,7, p);
p = x21; dis_one_zi (3,0, p);
p = x22; dis_one_zi (3,7, p);
p = X1; dis_one_zi (1,1, p);
p = X2; dis_one_zi (1,2, p);
p = X3; dis_one_zi (1,3, p);
p = X4; dis_one_zi (1,4, p);
p = X5; dis_one_zi (2,5, p);
p = X6; dis_one_zi (2,6, p);
p = X7; dis_one_zi (1,5, p);
p = X8; dis_one_zi (1,6, p);
/ * 128x64 * /
p = X9; dis_one_zi (2,1, p);
p = X10; dis_one_zi (2,2, p);
p = X11; dis_one_zi (2,3, p);
p = x23; dis_one_zi (2,4, p);
LCD_C_D (1,0 X3F);
delsimas (); vėlavimas ();
CLRLCD (0);
LCD_C_D (1,0 X3E);
p = X12;
for (numeris = 0; skaičių <4; numeris )
for (i = 0; i <8; i )
(Dis_one_zi (numeris, i, p);)
LCD_C_D (1,0 X3F);
CLRLCD (0);
LCD_C_D (1,0 X3E);
p = x13;
LCD_C_D (1,0 X3F);
CLRLCD (0);
> Ar kai kūno paversti šiuos kodus ir surinkimo.
Žinoma.C-compiler galėtų.
Apperently, tai yra skirta 8.051 ir Keil konkrečių fragmentą.Jūs galite naudoti kitus '51 kompiliatorius pvz sdcc, bet jums reikia padaryti keletą pakeitimų (pvz., kaiščių uosto apibrėžimai yra šiek tiek kitoks - Skaityti vadovą).
JW
